Use this command to clear a VLAN to policy mapping table entry or to reset the maptable response to the default value of policy mode.
| maptable | Clear VLAN ID - Policy Profile mappings table. |
| response | Specifies that the response should be reset to the default value of policy. |
| vlan_list | Specifies the VLAN ID or range of IDs (1 to 4094) to clear. |
N/A.
This example resets the policy mappings table response to the default value of policy.
unconfigure policy maptable response
This command was first available in ExtremeXOS 16.1.
